none of this really applies to me, as I plan on using standard tools and method with an alternate bearing.
However, I believe you can use any puller you like if you brace it against the sprocket, not the case. Slide Hammer would be a very bad solution. If you had your bolt snap, you would probably have to create a hybrid between the LN puller and a Kukko puller such that you are pushing on the sprocket.
Silber
