Thread: RPM fluctuation
Old 07-21-2017, 06:47 AM   #2
jcslocum
Project Addicted
jcslocum's Avatar
Originally Posted by mountainman View Post
Cleaned the MAF and throttle body and checked around for vacuum leaks, which I didn't find. Still have fluctuation. Any other ideas?
There's a LOT of hose on a Box, so you will need a smoke machine (easy to make) to get a full test. Duramertic would be helpful if you had one.
The booster was hard to test because it takes a bit of vacuum to pull it down to check. A vacuum pump is helpful. We could hear ours leaking with my head under the dash when that car was idling.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
