Old 07-21-2017, 05:35 AM   #11
Bilmar72
Bilmar72
Fog lights on with ignition
Do you just want the fog lights on at all times when the ignition is on?
If so, pull the headlight switch and connect a jumper wire between the violet wire and the yellow with white stripe wire, which are both on the headlight switch connector (back of switch - do not sever them from the switch, just jump between them).
That will do it on UK cars.
Particlewave you are brilliant. The above works for Australian cars as well. So simple. Thank you.
Bilmar72 is offline   Reply With Quote
