I do have the Drive Cycle and Readiness instructions ready, as soon as I have the problem fixed.
My OBDII does graphing and has been helpful. Durametric someday.
The SAI Pump comes on (cold start) and runs for a bit and then shuts off like it has always done. I believe it is good.
I have yet to start poking every connection and I am hoping it doesn't come to that. I am concerned I may cause old brittle plastic to snap making the problems worse. I will try your suggestion of using a longer hose with the propane. I also have a camera/snake that I have poked into most everywhere.
I think I have enough data to justify replacing the MAF. Thanks again, both of you for sharing your ideas. Safe travels.
