Thread: Cel 1124 & 1126
Old 07-18-2017, 06:54 PM   #3
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
does the engine stumble and then recover as expected?
I also still worry about the MAF. You could try clearing the codes and disconnecting the MAF. Then drive the car. I would expect the engine to run poorly at first but then improve. If the problem is the MAF, the codes won't come back. If you have an air leak (or something other than the MAF), the codes should re-appear.
1. Yes
2. So far, so good. I have driven farther than it would take to trigger the 1124/1126. I did get 0102 and 0112 almost immediately after disconnecting the MAF and starting. Which I think makes sense cause it is missing entirely. So I agree that it looks like the MAF needs R&R.
Thanks for your time/input.
