Old 07-18-2017, 03:39 PM   #1
JFP in PA
Originally Posted by Silber View Post
Will be using the original center bolt. It mainly seems to fail when the bearing fails, and by then it is too late anyway.
We have had a handful of the factory center bolts fail while the bearing was still in working order. Then tend to fail adjacent to or at the under cut for the small O-ring. LN's kit uses a much stouter center bolt without the severe undercut for that reason. As you also stress the Hell out of the center bolt extracting the OEM bearing, I am not a fan of this approach. But it is your car, and your money.................
