Old 07-18-2017, 12:43 PM   #486
McHeinzky
What's over asking? Mileage is important but at the age these cars are at maintenance is much more important. If there is proof of maintenance throughout the years the the Boxster in question is likely a better candidate then a low mileage garage queen that has had little done over the years. Keep in mind there is no such thing as a cheap Porsche. You going to pay now or later with later generally being more expensive.
The one I looked at this weekend was a 2002 Boxster S with 66,000 miles that he wants $12,000 for. The only records he had were oil changes from a Jiffy Lube type place. He said he bought the car from an auction and has had it for 5 years, putting 16,000 miles on it. He only has one key, no windscreen, and the tires that came with it. He has also never heard of an IMS bearing. I figure I'd have to drive it straight to my local Porsche expert and get the following:
IMS bearing
New clutch
Replace the rear main seal
Four new tires.
Then, I'd want to do the following:
Add the wind deflector
Replace the missing cruise control cap
Add a magnetic drain plug
Replace the dented spoiler cap
Replace both drop-down window switches
Order a new owner's manual (if possible)
Program a new key
I calculated all those to add up to about $5,500 - $6,800, assuming nothing else was discovered during a PPI.
I'm also hesitant to buy from someone who owned it for 5 years and didn't know they had a rear spoiler that extends at high speeds (I showed him how to put it up).
McHeinzky is offline   Reply With Quote
