					Originally Posted by Rotmilky  Oops.  Missed that one.  I does not seem noticeable different if I pump the brakes after it bottoms out.  Pretty much the same slow bottoming out no matter what I do. |
Then I agree with you 100% that it must be a leak where the fluid goes from one part from the system to another. My vote is then that the problem lies in the ABS or PSS (if you have it) systems. If you have PSS my vote is there since the car can activate the brakes without you touching the brake pedal.
