If your Traqmate logger can read K-line your all set and should be able to get Water temp, Throttle position, etc.
Most loggers use CAN for data from the ECU. Unfortunately Porsche was a bit behind other marques in getting that protocol to their ECUs and didn't really get it together until around 2006.
K-line unfortunately has very slow sampling frequencies (<10Hz) so there is some delay in sensor readings.
For Oil pressure you need to install a sensor since the 986 doesn't have one.
