Put the jack under the forward point of the diamond shaped plate, between the two bolts. You can safely support the rear from that location, but it requires a long/low jack. Do not use the back of the plate near the exhaust, it cannot safely handle the weight. Make sure you use wheel chocks on the front wheels, since the car is RWD.
