I have the exact same setup. I have 15 mm spacers all around and I keep them on permanently for my daily driver 18 in wheels, and for the 17 in track setup.
17 in wheels before and after 15 mm spacers:
You really need 15 mm in the front IMO. You could probably get away with 10 mm in the rear though.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
