Originally Posted by heymanwatchthis
You may want to take a look at your rake - I understand the back should be a little higher than the rear - too high and you get oversteer, so be prudent.
Good luck!
Thanks for the suggestion. The car sits a bit higher in the rear at rest, so I'm not sure that's my issue here...that seemed to change after the suspension install, actually.
