Thread: Battery Drain
Old 07-10-2017, 04:47 PM   #4
Anker
I had a similar problem that ended going away. When the instrument LEDs failed to extinguish the battery would last about 3 days before going flat. My initial "solution" was to put a trickle charger on the battery. I am sure the problem is the ignition switch, and I bought one that I still have to install.
The winter project is going to be long: AOS replacement, O2 sensor replacement, manual transmission fluid replacement, MAF and TB cleaning, ignition switch replacement, and I am sure several more items.
I am trying to wear my HTR Z II rear tires down so I can replace them with sticker tires. The HTR Z IIs wear quite slowly. 3 track days and two AXes and they still have decent tread.
If Santa grants my wish I will also install a duck tail spoiler. Still working on what I want for my birthday in February.
1941 Dodge Luxury Liner Coupe
