Originally Posted by 911monty
Man I expect someone to jump from headlight washers not working to the IMS. LOL.... The precat 02 sensor output adjusts the injectors fuel pulse attempting a stoichiometric AFR. If reading incorrectly this can cause a lean/rich condition. A lean mixture can cause misfires as well as holes in piston from detonation if severe enough. I'd say the pre cat 02 sensor bank 1 is a likely culprit.
Thanks. Job for the weekend. Fingers crossed.
