Old 07-07-2017, 06:16 PM   #5
moresquirt
Sorry NewArt ,(Thx for the numbers) but I'm not that techy,regarding the info u gave in the chart above.Can u advise what part is what torque based on my info .I just know what bolts to remove to get the Control arm replaced.There are 2 bolts on the Control arm itself one at the U (with a nut near the wheel) and one at the bushing or ball joint.(other end) Then it looks like there are 2 that need to be cracked loose to get the arm out.One looks to go into the frame (At end of Boomarang bracket I believe its called)and one or two (cant recall) go to the Stabilizer Bar Bracket/bushing.
Can u advise again based on the way I have explained.Much Thx
moresquirt is offline   Reply With Quote
