Old 08-09-2006, 06:24 AM   #1
no_substitute
Driver Window not Dropping
New to this forum, look forward to the sharing of info. First off, I am having a problem with my driver's side window. Window just does not drop enough when trying to open the door. I have heard many reasons as to why and how this may occur with no real conclusive results. The microswitches are working (the window jiggles down a little when you engage the microswitch without opening the door and goes up when you release the handle), the window works under normal switch opeation and top operation, the window can be pushed down to correct positon to close door and once shut the window moves up. - Thanks in Advance!!!
no_substitute is offline   Reply With Quote
