Old 07-05-2017, 02:44 PM   #1
Need_for_speed
As a little hack, just reposition the temp sensor for the Engine Compartment closer to the crankcase(heat source). It will come on sooner and stay on longer. It will also come on even after you remove the key -heat soak.
That sounds like a great idea. Is this something you've done? Can you provide any details or photos? Not sure where the temp sensor is located.
Need_for_speed is offline   Reply With Quote
