Old 07-05-2017, 01:21 PM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
Simple answer is yes, the engine blocks are interchangeable, but there are some peripheral items that must be swapped from one to the other.
A few years ago I swapped an 01 manual 2.7 into a Tiptronic 2.7. I detailed the differences in a couple threads since then. Nothing major as long as you have parts from your original to swap to the replacement. Vacuum lines are a little different including the brake booster vacuum. Engine wire harness needs to be swapped. Intake tubing was slightly different. Alternator and starter have slight differences, but are functionally interchangeable. Probably a couple other minor things I can't recall.
