Old 07-05-2017, 10:44 AM   #2
Need_for_speed
You can add a manual switch to trigger the engine compartment fan, however the relay is located in the trunk, so running a wire to the cabin is troublesome. I have found that adding a switch for the high-speed radiator fans is sufficient to keep everything runnings at acceptable temperatures. Those relays are in the driver's footwell so it is much easier to install.
Engine Compartment Fan Manual Switch
Actually, this would be a great idea for track days. You could turn the fan on between runs to help the motor cool down.
Great...all the photos in the link are gone because of the 3rd party photo issue. All the work Tom and others have done to help us, now gone.
That said, thanks to Tom's post I am now aware that the fan will actually come on when the engine is off if the temp is high enough. Makes me wonder if the manual switch is actually necessary...
Need_for_speed is offline   Reply With Quote
