Old 07-05-2017, 09:51 AM   #1
rick3000
There Is No Substitute.
rick3000's Avatar
You can add a manual switch to trigger the engine compartment fan, however the relay is located in the trunk, so running a wire to the cabin is troublesome. I have found that adding a switch for the high-speed radiator fans is sufficient to keep everything runnings at acceptable temperatures. Those relays are in the driver's footwell so it is much easier to install.
Engine Compartment Fan Manual Switch
