Old 07-05-2017, 05:55 AM   #153
Anker
Originally Posted by redciv1 View Post
BTW, if no fuse taps then you can easily take 16-18g wire, strip both ends and then wrap one end around one blade of the fuse and then take the other end and wrap around the 86 relay terminal. This is the way I have mine setup.
Not a good idea. If you make the connection on one fuse leg the fog leg connection will be unfused and if do it on the other the fuse risks being overloaded when you turn the headlights on. Good fuse taps have a fuse on the tap. They are inexpensive and easy to order from Amazon.
1941 Dodge Luxury Liner Coupe
