Thread: ABS Failure!
Old 07-03-2017, 11:43 AM   #8
JFP in PA
I would not normally question you, but the 4210 code explanation I got says right side, not left. Since you said you were away fro your shop, that makes a bit of sense
I checked the left and right sensors and the left one reads 1.7k and the right .4k
I swapped out the right sensor with one from my 996 and ABS works properly. I cleared the codes and will see if the P0501 comes back
As I mentioned, I am away from he shop at the moment, so I do not have access to my OBS II manuals and am going purely from memory, but I do recall P0501 as being a communications issue for the left sensor on a Boxster. Off hand, I do not recall the 4210, so I did not want to guess on that one. I just placed a call to someone that does have access to the manuals, and he confirmed P0501 as being the left sensor. He also drew a blank on the 4210 code.
If you got it fixed, more power to you, but P0501 is for the left sensor.
