Old 07-02-2017, 06:56 PM   #2
JFP in PA
Originally Posted by Rob175 View Post
While it may be a "cheap DIY project" it's certainly NOT easy or simple! There is a long thread in the Boxster section (with pictures) that shows whats involved. IF you think you'd enjoy taking the dashboard apart then go for it. Otherwise hire someone and pay the huge cost or live with it. (I carry a tweezer in the car so I can pull out the larger pieces when they get caught in the vents)...........
But you are correct IT SHOULD NEVER HAPPEN and Porsche should have addressed ir years ago.
(1) I have done several of these, it is both easy and simple, but perhaps that is just my view.
(2) Let's look at the perspective of Porsche fixing it: When the IMS failures occurred, and $20K engines became boat anchors, Porsche did everything in the power to avoid taking responsibility, and even continued that tact in light of the class action against them. And you expect them to take responsibility for some dried out foam that is more annoying than a real problem? Good luck with that...........
