Old 06-30-2017, 06:09 PM   #1
bmsamson
Originally Posted by BoxsterSteve View Post
Clock spring is done... can be repaired DIY
Micro switch on the affected door is pooched, also DIY, you could get a repair estimate for the jobs at a mechanic and use it as a bargaining chip if you're so inclined.
no time to check with a mechanic, that's why i'm asking you all, in case someone's had either/both jobs done recently.
yes, probably i could DIM, but won't get as much off the ask that way
bmsamson is offline   Reply With Quote
