You can get a small ultrasonic cleaner for cheap at Bed, Bath & Beyond for cheap and they always have a 20% off coupon. I have one and use it for bicycle chains and other small pieces. It also works for jewelry. Nuts and bolts are about all from a car that will fit in it.
So, back to anti-seize. Should I be putting it on the threads of my lug bolts? The last time I used it for wheels was for the wire wheel splines on my Austin Healey 3000. It did a much better job than grease which dried out and let the wheel and hub splines corrode together.
