Old 06-29-2017, 07:07 PM   #4
Boxstard
Originally Posted by tommy583 View Post
I had a similar problem. It ended up being a totally clogged charcoal canister. Put in a new used one and haven't had a hesitation since. I just took all the tubes off of the canister and tried to blow through it. Could be something to look into.
Interesting, but I thought the canister gets basically purged at idle when vacuum past the throttle body is high, and at 6,000 rpm the purge valve is closed so the flow through the canister is irrelevant. Anyway I'll check it out, first try to blow through it.
