I would like to know if this is possible as well......It doesn't come back to the mode it was in before you shut off the car tho, I turn mine off most of the time, unless the temperatures are extreme (cold or hot)..... Always starts up automatically when I start the car...
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
