I recently replaced all 4 of my struts. I looked hard at that method cause I do like to try to disturb as little as possible and not have to use spring compressors. Disassembly I believe is doable. However I decided reassembly would be a bit more difficult when trying to ensure the plastic spacer below the top mount was installed correctly (clocked to the bolts) and then to stab the shock piston shaft through the top mount while maintaining the spring correctly positioned in it's bottom mount all while jacking up. Probably impossible if you're working by yourself.
