Thread
Brake pedal stops normally then slowly fades to floor. Master cylinder? Booster?
06-26-2017, 01:11 PM
6
Racer Boy
Racer Boy
The first thing I would check would be the bleed valves on the calipers, make sure that they are tight. Most likely you'll have to fix(rebuild/replace) the master cylinder. Your symptoms are what normally happens when the master cylinder goes bad.
Racer Boy
Find More Posts by Racer Boy
