Old 06-25-2017, 09:42 AM   #3
AZ986S
AZ986S's Avatar
I just went through this. What exactly are the codes?
One thing to check before anything would be your camshaft deviation values.
High values could indicate variocam worn ramps (as mentioned below) or more serious issues. If you are getting Misfires for those particular cylinders (1-2-3) on one side only, then I it could be O2 sensor on that side, or maybe a camshaft position sensor. I had issues with multiple cylinders not just on one side. I ended up replacing all 3 hydraulic chain tensioners as well as all 6 coil packs since a couple were bad. One of the spark plugs was loose too, so that also was a contributing factor. I've had similar misfire issues before and I cleaned the MAF sensor and went away. I doubt all 3 coilpacks went bad at the same time. Vacuum leak maybe? AOS?
Have you upgraded the IMS bearing? Don't drive it until you have fixed the problem.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
Last edited by AZ986S; 06-25-2017 at 12:02 PM. Reason: Just saw your signature on the IMS upgrade...
AZ986S is offline   Reply With Quote
