Old 06-25-2017, 08:41 AM   #2
redciv1
redciv1's Avatar
Exterminate the halogen! Yay!!
1. Can't remember but it was quite a bit of material and needed pretty custom art to get them there and somehow closely aligned with the car.
2. Reseal with sealant, if you don't fancy cutting a plate out of sheet metal or thin sheet of aluminum. If memory is good
3. I use Butyl on the headlights that I personally service here, however I (and most, I think) do recommend silicon-based sealant (much stronger). Later can also be removed but require considerable heat and lot more wrist-energy :/
Hey Nine, yes, extracting of the halogen. Definitely required far more material than I thought but WORTH EVERY HID GLOW. I was thinking of using maybe aluminum tape on the inside. I thought about using the Butyl and aluminum foil on the back side to seal up as well.
I think I will go with the Butyl as well.
Last question. What do you use after the headlight is out of the oven to hold headlight tight so it seals?
redciv1 is offline   Reply With Quote
