Old 06-24-2017, 08:37 PM   #11
bwdz
Originally Posted by rexcramer View Post
Dorman has been making split CV boots forever. I remember using them on my VW +/- 40 years ago. I've used them on a Saturn and a Subaru. No need to pull the axle out, disturb the wheel alignment, spending hours of time fighting with frozen joints and high torque nuts.
There has to be a boot in their catalog that would work on our Boxsters. I just sent their tech support an email.
Those split boots are a decent temporary patch but in no way do they really save the axles or last all that long from my experience. If your boot is torn, not only did the grease leak out but dirt likely got in there and the grease that is there is contaminated. The cv needs to be taken apart (use a brass hammer or plastic mallet to pop them to not damage anything) it needs to be cleaned, repacked and use factory style clamps if you want it to stay on tight, the tool to compress them is cheap like $10 on ebay. This is pretty simple and if you are unsure how to do it just watch some youtube videos. One other thing to keep in mind is that you are supposed to replace the axle nut and it is ok to impact them off but they need to be torqued to spec going back on, you can keep the hub from spinning by using the parking brake or just put a screwdriver in the vanes up against the caliper to hold it. Not using proper torque or excessive torque from an impact will cause premature wheel/hub bearing failure that may take a few months or even longer to show up but in extreme cases of over torque it can show up much sooner.
bwdz is offline   Reply With Quote
