Thread: Overheating?
Old 06-22-2017, 11:21 PM   #10
Coaster
Coaster's Avatar
Originally Posted by Snipershot View Post
I think im gonna change the water pump myself. Im leaning towards the Pelican kit with the low-temperature thermostat. Anyone used that kit? It has a composite impeller instead of metal, so im curious if it will last.
Joe
I'm not an expert in this area. I believe the composite impeller is OEM.
Composite
Pro won't chew up block if bearing goes bad
Con Could break and leave pieces stuck in cooling channels causing hot spots and additional damage
Metal
Pro won't break into pieces
Con, could chew up block if bearing goes bad rendering block unusable.
Some consider the WP a consumable and replace at XX miles or XX years.
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is offline   Reply With Quote
