Vent foam
The process I suggested is not to be done while driving so it does not affect the air temperature while driving. I did it to see if it resolved the frequent pieces of foam from shooting out the vents. I open each vent with the A/C on full blast for maybe 5 minutes each with the vacuum on and its nozzle brush flush against the open vent (and the other vents closed). After I repeat this with each vent, I then open all the vents and resume using the A/C as usual. I have only had a couple of small pieces of foam come out in over a year which I think is pretty good.
