Old 06-20-2017, 06:12 PM   #1
Nine8Six
Nine8Six's Avatar
Originally Posted by Filastein View Post
It's pretty easy to see if all four pins are engaged.
True.
Do this, remove the passenger side and measure/compare the height of each side rails in the fenders. Suspect the driver's side bracket gone out of alignment. For whatever reason... double check that. Those headlights are the correct ones and will fit.
Can't be the connector, that is the last 10mm slide they will see. The headlight should already be flushed with the bumper before reaching to that back connector.
