Originally Posted by husker boxster
Before you change your oil, pull the filter cap and dump the oil in there. That should take you down a half to full bar. Rinse and repeat until you get to the proper level.
Do I need to start the motor (once the filter is placed back on securely  ) to have the pump refill the filter cap (in order to repeat the process)?
2001 Boxster S, Guards Red
