Old 06-20-2017, 09:31 AM   #2
pidj
pidj's Avatar
Before you change your oil, pull the filter cap and dump the oil in there. That should take you down a half to full bar. Rinse and repeat until you get to the proper level.
Okay. This is my first mechanical thing with the car . I have never removed the filter on a boxster - so I understand that the oil is not going to spew out as if you removed the drain plug nut .... I'll check some videos to understand the way the cartridge filter works. I don't have a replacement one, so is it okay (or even possible) to reinstall after I drain out some oil?
Thanks!
2001 Boxster S, Guards Red
pidj is offline   Reply With Quote
