Old 06-20-2017, 07:42 AM   #1
pidj
pidj's Avatar
Turn the car off and let it sit for about an hour, then turn the key to the on position and let the dash oil gauge run through its cycle. If the dash gauge, which is more accurate than the dipstick, says the oil level is near the upper arrow, you are fine. If the car was overfilled, all of the dash bars would be lit.
Thanks JFP, Shoot. The attached graphic is a cold test after sitting overnight. Sounds like it may be best to just change the oil now, and refill with a lower volume?
2001 Boxster S, Guards Red
pidj is offline   Reply With Quote
