Old 06-17-2017, 07:40 AM   #11
BruceH
BruceH's Avatar
Originally Posted by gtoger View Post
Thanks for that. Actually I don't want more sound than the stock. The real reason for changing was all the heat that the factory exhaust bakes the trunk with.
Unfortunately we're in an emissions control area and cannot remove the cats. So no "test pipe" for me.
You can get rid of the secondary cats and still pass. I am in the DFW area and pass with no issue with the test pipes. All the test pipes do is remove the second set of cats. The only time my exhaust gets annoying is if I am below 2900 rpm, but shifting takes care of that Even then, the sound is not a drone which is what I had before I put the EZ clamps on.
Search Results
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
