					Originally Posted by  patssle
				Does that cover the entire flapper? I thought it's longer than that? That method definitely beats every other method if it gets the job done! Mine has also spit out all the foam. A/C is fine but heat doesn't get too hot. Thankful for seat warmers.
With the way you cut it up open, can you get to the bottom of two flaps to tape up holes all the way down? From pics it looks as if only top half of those flaps are exposed and accessible.
