Old 06-16-2017, 12:21 PM   #10
rfuerst911sc
Originally Posted by gtoger View Post
Thanks for the suggestions, all. I'm going to start with the CC inserts first and see how those work out. That seems to be the easiest, least-invasive option for us. If that does not produce good results, then we'll move on to the next step. (whatever that may be).
I highly suggest you use the stainless steel packing with the inserts . It seems to knock down some of the DB but not too much . Make sure you take good inside diameter measurements of your tips . Match up the closest outside dimension inserts. I found on mine I had to slightly grind down the O.D. of the inserts to fit snugly . But it all depends on what your exhaust tips measure . If I remember correctly I went with 6 " of center perforated tube with two discs . I welded the discs so one was deep inside the tip and the other was aprox. 1/4 " from the end of the tip . The space between those two discs I filled/wrapped with the stainless steel packing . Yon don't need anything to hold the packing it is sandwiched between the inner metal tube and the two discs , it is not going anywhere . Good luck I don't think you will be disappointed .
rfuerst911sc is online now   Reply With Quote
