Old 06-15-2017, 07:51 AM   #1
Rob175
Rob175's Avatar
Small foam pieces blowing from vents
My (otherwise perfect) 1998 Boxster with 80M miles occasionally blows out small pieces of dark grey foam from the vents (dashboard and floor). Its not an everyday occurrence but still it happens from time to time. The heat and the AC both work fine and the fan blows perfectly at all levels. The pieces range in size from pea size to nickel size with the larger size sometimes getting stuck in the vent louvers so I remove those with a tweezers. I'm wondering if on a car this age it's not uncommon or if it's something that I should have looked at?? Everything else is fine.
Rob175 is online now   Reply With Quote
