Old 06-14-2017, 05:43 PM   #3511
Anker
Wings and Wheels tomorrow, and on Monday we are off to Nova Scotia for a couple of weeks in the Boxster.
First thing was to check all the drains, since it will be parked outside in Nova Scotia. Glad I did, because the left rear drain was completely blocked and the right front drain was partially blocked. There were also leaves and other debris in the foam "funnels". Got them cleared and then decided to have a peek at the engine, so I pulled the carpet, sub woofer and the engine cover. A lot easier than I expected. The engine can use a bit of cleaning, but that will have to wait.
After that I did a thorough wash and checked the tire pressures all the way around. Had lost about 10 PSI on each tire after cooling down from the HPDE at Thompson.
1941 Dodge Luxury Liner Coupe
