Old 06-14-2017, 08:18 AM   #1
spinedoc
Okay Boxster Wrenchers...ignition ?
My '98 986 has an issue with the ignition key module.
When I turn the key to crank it on, it get's stuck in the "right" position, and many of the electronics including fan/ac/etc. are all weak, this includes headlights.
I have to manually crank the key back to the left about 25 degrees or so, then everything works perfectly. Unfortunately, sometimes, it cranks back to far and shuts the engine off.
Which part of the ignition do I need to replace? Which parts?
Is it just the ignition switch???
Anyone replaced on before? Hard, not too bad?
Kindest,
Mike
'98 Porsche Boxster
spinedoc is offline   Reply With Quote
