Old 06-13-2017, 06:28 PM   #24
Jager
Jager's Avatar
Originally Posted by Nmbrsix View Post
What an impressive achievement!
I'm curious to know what your maintenance regimen has been, and what parts you've replaced either due to failure or preventatively other than the IMS. What about the AOS? Water pump?
Have you had the timing chain guides replaced at any point?
What oil/filter do you run, and how often are you changing it?
How hard do you drive it?
Here is something I wrote a couple years ago that shows some of the maintenance:
Thinking of buying a Boxster? I have over 255,000 miles on my 2001 Boxster and can easily say it’s the best car I have ever owned. Not only is it a blast to drive (my daily driver) it’s the only car I have owned that has not left me stranded. I enjoy working on cars almost as much as driving them so that helps in keeping the cost of Porsche ownership down. There are routine items like changing the oil/filter, air filter, wipers, fuel filter, plugs, fan belt, and tires that I have done a number of times, but here is a list of other maintenance items I have done to my Boxster over the years (these are not necessarily in order but close):
Replaced windshield – Pro installed
Replaced rag top (cracked rear plastic window – don’t operate the top in cold weather) – Replaced myself
Replaced brakes and rotors – Myself
Replaced the battery -Myself
Replaced fuel pump (going bad) – Pro
Replace Air Oil Separator – Pro
Replaced the ignition switch -Pro
Replaced water pump (leaking) – Myself
Replace gas cap (seal cracked) – Myself
Replaced Air Oil Separator again (DO NOT OVERFILL MOTOR WITH OIL) - Myself
Replaced IMS Bearing, rear main seal, clutch, and the flywheel – Myself (210k miles)
Replaced all O2 sensors – Myself
Replaced front motor mount - Myself
Replace mass air flow sensor (no issues, now I have a spare) - Myself
Replaced all spark plug coils (no issues, preventative maintenance) - Myself
Replaced the seals on the oil cooler (no issues, preventative maintenance) - Myself
Replaced turn signal/cruise control switch group – Myself
Replaced headlights (entire assembly) – The plastic lenses had serous road rash after 200,000 miles
Replaced covers to the key fob remote controls - Myself
Replaced hood and trunk lift struts – Myself
Replaced the oil cooler and seals - Myself
Replaced driver’s side window regulator and locking switch – Myself
Replaced the front bumper (I hit a coyote) – Pro
Replaced the secondary air injection system cut-off valve, vacuum reservoir, electric cut-off switch – Myself
Replaced brake pads and rotors again @240k miles – myself
Replaced the rear track control arms- myself
Replaced the trailing arms - myself
Replaced the rear struts and top mounts – myself
Replaced IMS bearing at 243,000 miles with LNE bearing… Again.
Replaced water pump 243,000 miles
Replaced evaporator valves miles
Replaced rear wheel bearings 245,000 miles
Replaced both axles 245,000 miles
Replaced front wheel bearings 250,000 miles
Replaced catalytic converter (bank 2) 253,000 miles
Replaced AOS again 259.600 miles
My Boxster has the original motor, original muffler. No leaks and motor runs great.
It's my daily driver, I have taken to the track once, cross country twice, but mostly to and from work. I do like to get on it at least once or twice a day... I love to hear 5000 to 6000 RPM out of the motor.
Jäger
300K Mile Club
