Old 06-13-2017, 12:42 PM   #2
particlewave
It's not that simple.
The switches are momentary, so depending on the light system you're using, the lights would likely only be on if you held the switch.
You'd want to wire it to a latching relay.
#1 & #2 would go to the latching relay and #5 to a ground that is active only when the lighting controller is powered on.
