Old 06-10-2017, 07:40 PM   #2
dulmer
dulmer's Avatar
Originally Posted by jakeru View Post
The 997 shifter reduces the throw (both front-to-back, and left-to-right throw) compared to the 996 shifter.
These aluminum bushings reduce the slop in the bushings of either the 996 or 997 shifter, which is predominantly has some play especially when under force I believe, in the left-to-right direction.
Even with these bushings installed, there will be other sources of slop in the shift console assembly, that could still be addressed/improved.
Thanks for the detail. My biggest issue right now is the side to side slop. Maybe I'll go with the 997 shifter, and add these bushings...
dulmer is offline   Reply With Quote
