Old 06-10-2017, 04:52 AM   #12
CBRacerX
Originally Posted by Singerdude View Post
Ooookay, at 3-3.5k, my enthusiasm is dwindling a smidge... :-)
Well the guys @ Eurozone told me they've done a bunch of IMS on earlier 986's 2.5 and 2.7's but had yet to see a failure on a late 3.2 wich is what I have. They also told me I shouldn't worry because with the mileage my car has, if it had a bad IMS bearing, it would have grenaded a while ago. Now they've inspected the car and found nothing wrong except for a link kit needing replacement and that the clutch engages a bit high and will need changing eventually. It could still last a while if I baby it, but of course I don't...
I don't know WeTune, I might look them up though, you can never know too many good mechanics... I hope your big job goes smoothly and you can get back behind the wheel soon.
Honestly that sounds backwards. Early cars are less likely to have failure because of double row bearing. Higher mileage car means the bearing has the grease washed out and replaced with seeped in engine oil (bad because it does not circulate). Later car more likely failure because single row bearing.
CBRacerX is offline   Reply With Quote
