Old 06-09-2017, 09:31 AM   #1
Supra-P!G
Originally Posted by rexcramer View Post
Wow, are those wide. You may need mud flaps on the back now.
Yes, they are super wide. I used 38 mm spacers on the rears. No issues with rubbing inside, only issue seems to be top of fender on extremely big dips. Will need to install spring stabilizers, or stiffer springs to eliminate that, but it's not bad.
I did read somewhere that the e-brake cables should be zip tied out of the way. The e-brake line seems to be strait and very close the inside wheel, but no touching. How is the line zip tied?
I've put on about 600 miles with these tires/wheels so far.
Supra-P!G is offline   Reply With Quote
