Good, the pic came through.
I originally thought the spring clamp by the right red arrow is where the problem was, so replaced with a screw clamp after making sure the hose is as tight as I could get it. But now the leak seems to be coming from the left red arrow, which I think is the bottom of the pump.
I should add that this is a two owner car before me, with 104,000 on it. I've driven it about 1000 miles since I've got it, and only now has this popped up. Had a ppi done, but this wasn't a problem at that point I guess.
